It is currently Sun Jul 20, 2025 3:49 am
 Post subject: Peghead Question
PostPosted: Fri Feb 01, 2008 9:57 am
Hello!
After doing four headstocks with a standard paddle style headstock I decided to try a slotted pehead on my current L-00 "style" build.
My issue is in regards to my slots. They are standard rounded on each end but I just realize that I will need to make "sting ramps?" at the bottom of each slot to allow the strings to access the tuning machines. Is there a standard measurement for this or is it an eyeball it thing? (Using Grover Sta Tites for my tuning machines)
Thanks!
Ray
Guitar Building = Continuous Improvement Process
 Post subject: Re: Peghead Question
PostPosted: Fri Feb 01, 2008 10:32 am
I just eye it, and when I'm getting close I place a nut at the end of the FB and then put a straight edge on the nut to the first post hole and verify that I am clearing the floor of the ramp.
PostPosted: Fri Feb 01, 2008 10:37 am
Lance, does that angle change after you slot the nut?
PostPosted: Fri Feb 01, 2008 10:56 am
Good point, yes you want to use something (anything) that would represent your final string height, or at least close to final height. ;)
PostPosted: Fri Feb 01, 2008 11:04 am
The terminus of a Martin ramp is almost touching the nut.
At least my little 00 is done that way.
I think it looks good, and you sure avoid the embarrassment of strings digging into your headstock finish.
PostPosted: Fri Feb 01, 2008 1:00 pm
Slotheads usually have a slender angle, around 12º vs. 18º for Martin I think. Some Spanish guitars have almost no angle on the peghead, which solves the issue of the ramp being too shallow.
Laurent Brondel
West Paris, Maine - USA
